- 17 Jun 2012
I have 8gb of Corsair Vengeance LP, both sticks pass memtest, one stick boots and runs flawlessly with no errors but when I swap to test the other stick I just get constant crashes and BSOD with all manner of BCcodes.
I've also tried the same test in another mobo with the same results, I initially thought this was a bad RAM slot on my main board but I must have mixed up the sticks when testing which confused matters.
Are RAM failures common? It's only a month old and all I did was install it and run it's XMP, it was fine up until the other day when I started getting all sorts of crashes etc.
