I'm running a new X2 3800 at stock, low case airflow, EVO 120 cooler, MX-1 paste. I had trouble aligning the cooler and I think that's messed up the paste, causing temperature problems. Or maybe not...
I tested using S&M maximum CPU heating test, with all tests selected on both cores. That reports an almost constant 100% load on both cores.
Speedfan 4.32 is reported odd core temps, varying up to 14C in a matter of seconds. I think that "temp 2" is one core and "core" is the other.
S&M's monitoring shows only one temperature reading from the CPU, roughly matching temp 2 reading from Speedfan.
I'm sure that the temperature of the cores, especially the second core, can't be varying that much that quickly. A glitch in Speedfan?
