- 22 Jul 2015
- Aberdeen
Motherboard Model : Asus X99-A II
Operation System / BIOS version : Windows 10/Bios ver 1902 (Latest)
Graphics Card: Nvidia Gtx 1080Ti
Processor: Intel 5960X
Memory: Corsair CMK32GX4M4A2666C16W Vengeance LPX 32 GB (4 x 8 GB) DDR4 2666 MHz
The system was running stable until a few days ago. It started to crash and then no boot with all the 4 ram sticks together in slots A1/B1/C1/D1. The system only boots with a ram stick in D1 or C1 or together in these two slots. No boot in any other combination or crash within first 10 mins even if it boots. I have carried out following steps to make sure that memory or no component other than motherboard itself is playing about:
- Booted with all the memory sticks one by one in D1 and tested the memory with memtest86. All of the memory sticks are error free.
- This is a matched set of 4x 8gb memory sticks and working flawlessly on this board for nearly 3 years now.
- I reset and loaded the optimised defaults in Bios and turned off the XMP to make sure that no OC is in effect.
- Tried CMOS reset.
- Re-installed windows.
- Removed the cooler and re-seated the CPU with no change in behavior.
Since all the memory sticks are confirmed to be working error free by memtest86 and system is perfectly stable with a single ram stick in C1/D1 or a combination of both; I think the problem is with the motherboard memory slots and probably a RMA is required? Can CPU IMC be the culprit?
Thank you
- Tried CMOS reset.
Thank you
