26 May 2006 at 13:10 #1 Conrad11 Conrad11 Soldato Joined 12 Jun 2005 Posts 5,361 Hi there, I just wanted to know if it was important for fav icons to be in a .ico format because you can use a png and it seems to work in firefox? Is it important for it to be in .ico format? Does it have advantages? Thanks...
26 May 2006 at 14:30 #2 Augmented Augmented Soldato Joined 18 Oct 2002 Posts 5,460 Location London Town Conrad11 said: Is it important for it to be in .ico format? Does it have advantages? Click to expand... Wider support, and favicon.ico is what may applications will look for in the root by default when attempting to get your site's icon.
26 May 2006 at 15:48 #3 Conrad11 Conrad11 Soldato OP Joined 12 Jun 2005 Posts 5,361 Augmented said: Wider support, and favicon.ico is what may applications will look for in the root by default when attempting to get your site's icon. Click to expand... Does that mean I do not have to link it in the head of the HTML....or should I still link it?
26 May 2006 at 15:53 #4 Augmented Augmented Soldato Joined 18 Oct 2002 Posts 5,460 Location London Town Conrad11 said: Does that mean I do not have to link it in the head of the HTML....or should I still link it? Click to expand... Yes, do link to it - that way you'll support both applications that automatically search for it, and those that look for a <link> in a page's <head> .
27 May 2006 at 11:12 #6 Conrad11 Conrad11 Soldato OP Joined 12 Jun 2005 Posts 5,361 Augmented said: Wider support, and favicon.ico is what may applications will look for in the root by default when attempting to get your site's icon. Click to expand... Sorry to bring this up again, so that means it's best to put it in the root directory, yes? What do you mean by root directory, in the same folder as the index page? Thanks...
27 May 2006 at 11:41 #7 Beansprout Beansprout Man of Honour Joined 31 Jan 2004 Posts 16,331 Location Plymouth http://[your domain]/favicon.ico If you don't put it there you'll be surprised how clogged your logs get with 404s, mainly from IE
27 May 2006 at 13:31 #8 arty arty Soldato Joined 18 Oct 2002 Posts 6,903 Location Stamford Beansprout said: If you don't put it there you'll be surprised how clogged your logs get with 404s, mainly from IE Click to expand... Funnily enough I noticed this ages ago. It's very annoying if you don't actually want a favicon; does anyone know of a way to get round it somehow? arty
27 May 2006 at 13:32 #9 Conrad11 Conrad11 Soldato OP Joined 12 Jun 2005 Posts 5,361 Create a blank favicon?
27 May 2006 at 15:41 #10 Beansprout Beansprout Man of Honour Joined 31 Jan 2004 Posts 16,331 Location Plymouth arty said: Funnily enough I noticed this ages ago. It's very annoying if you don't actually want a favicon; does anyone know of a way to get round it somehow? arty Click to expand... 'touch favicon.ico' I create favicons and 404 pages by default since it's astounding just how much of the log files are crap. Look at this, and this is only 6 days: Code: grep favicon.ico /var/log/httpd/error_log | wc -l 24101 And for non-existant 404 pages: Code: grep '404.shtml' /var/log/httpd/error_log | wc -l 66062 Out of a total number of file not found errors: Code: grep 'File does not exist' /var/log/httpd/error_log | wc -l 264625 That's just insane - nearly 35% caused by no favicon/404
27 May 2006 at 16:43 #11 Moredhel Moredhel Soldato Joined 11 May 2004 Posts 4,789 Location Gloucester For widest support it's best to use two different link elements. <link rel="shortcut icon" href="/favicon.ico" type="image/x-icon" /> <link rel="icon" href="/favicon.ico" type="image/x-icon" /> Only one is the "standard" way of doing it, but browsers that implemented it before the standards were finalised use the other method.
