Favour - Do These Dropdown Menus Work For You in Chrome?
24 Sep 2007
Hi Guys
Can someone using a recent version of Chrome go to:
http://www.motorola.co.uk/
and mouse over the Mobile Phones menu item top left. Does it bring up a dropdown menu? I just want to know if my computer is the problem or whether it's their website.
I am using Chrome Version 41.0.2272.118 m.
Thanks for the help.
OK, thanks. I had a feeling it would be my computer.
Are there any simple things to check in Chrome? I don't remember switching anything off. I am using a Surface Pro 3 with a multi-monitor set-up.
works fine for me too, drops down to 'mobile' menu at around 950px.
Desktop version changes 'font size' on menu at around 1100px. Shouldn't be any issues with sp3's resolution unless the os zoom has been changed.
Have you tried a Ctrl + F5? I was having some issues with a site the other day which worked after doing that!
Could be worth trying it without any extensions / addons turned on in case something may be messing with the display.
Look for errors in the Chrome console (F12).
Dropdown works at two largest breakpoints for me, at the smallest breakpoint it's an accordion list.
