I have always ended up with generic cases with a slight rebranding on them, my first windowed case was like this.
Now I have a Thermaltake VA8003BWS case. I need to fit a pair of cut up tights to act as a filter for the 25cm fan on the side, as it's just blowing dust into the case. It's quite odd how they designed it - every other intake has a filter apart from the big fan (half assed Thermaltake?).
Other wise the build and quality of the case is the best I have ever dealt with. My only other complaint would be that the screwless locking mechanism for PCI/PCIe cards isn't very good.
Windows are quite easy to put in yourself if you have a dremel or angle grinder. Put one in on my Antec Titan with the help of my gfs dads angle grinder:
don't even need that, i used a small drill bit to make a pilot hole and then drilled a 8mm hole and just poped my jigsaw through and away i went along my sketchy pencil line
Liked my Eclipses' window, not gonna post a pic cos theres so many around, but I will say - Love the looks on the Mountain Mods Cases like that, pity its' just too big for me
