Favourite mouse - double click issue
Caporegime
13 Jan 2010
Llaneirwg
My trusty g700 has the dreaded double click issue.
Is there any way at to fix this? There's no other mouse I really want!
I know there are software options, but I use this on a work pc too. So that isn't an option
My MX500 did this a month or so ago, lasted about a week and then it stopped. Shift + arrow key is one workaround for selecting text. The scroll wheel stops working occasionally too, it's getting old like me :p
Remember my beloved old g7 wireless getting that
Vaguely recollect taking it apart and bending the bit of copper inside the switch a tiny bit
Very fiddly from my memory of it
In the past I've bought omron microswitches for a few quid on eBay and soldered them on. You'll need a soldering iron and a desoldering pump (or a desoldering wire). It's pretty easy to do, as long as you can get the mouse apart safely :)
The switch you typically find in mice are d2fc-f-7n.. try to get the 20m click variant (or higher) if possible.
Yeah I don't have a soldering iron unfortunatel
Some it the videos have no solder options may give it a g . Never wanted to fix broken tech before
