Hi All
We are having a massive reshuffle at work and installing cat5e wiring throughout.
All our voice and fax and adsl lines come in upstairs. As far as data and voice is concerned that is fine. But the fax machine needs to moved downstairs.
My question is, can I patch the fax line through our patch panel and down to a network point downstairs and use a rj45 to rj11 adapter to plug the fax into the outlet.
If so, what is the best way to wire it.
I was thinking of wiring a length of cat5 into the patch panel on one end, and an standard phone plug on the other and sticking it into the master phone socket which is upstairs in the same room as the rack and patch panel. Then via the patch panel, patch that port down to the network outlet downstairs.
What wiring convention would be best for this.
Thanks in advance
Aaron
Thanks in advance
Aaron
