FC Terminal Dual Serial
9 Jun 2014
Plymouth UK
Hey guys,
Longshot but does anyone know where i can find the rectangle/oval gaskets that fit this block. Bought one second hand and it didnt come with any..... tried normal O-Rings and i am either being stupid or they wont work .......:confused:
Your original FC blocks don't have orings on their terminals? The dual terminal block doesn't come with any, as you're supposed to use the ones that are already installed on the water blocks and place them on the bridge.
Contact EK and they'll provide you with some if that's the case.
On this subject can someone help me, ive just got a fc titan se block and its missing the 3 x screws and orings for the acetal terminal, i see they do a clear plexi terminal, does this come with the screws, i know it comes with the o-ring gaskets.
I don't think they do as they assume they come with the block. However contact EK directly and ask them for some and they should help you.
Hey guys,
Yeah kinda knew that ..... problem is i got it second hand and they aren't here ...... :(
That's a bugger that the previous owner didn't provide the o-rings :(
The O-ring size you need is 15x1mm (NBR70) 15mm being the inside diameter of the o-ring.
If you can't find some in a hardware store, you will have to contact EK (http://www.ekwb.com/support/) since we don't have a replacement part section in the webshop.
thanks ive just done that, trying to find EK luc in the forums aswell.:D
I'm here!! :D
Sorry i'm still a little bit delayed with the PAX East that ended on sunday.
Again I don't understand why the previous owner didn't provide the o-rings and the screws :(
The O-ring size you need is 15x1mm (NBR70) 15mm being the inside diameter of the o-ring and the screws are M4x28 DIN7984.
Our multiple GPU bridges don't come with the screws and o-rings since you're suppose to use the ones you already have. We only give one screw and one o-ring just in case. So you would still be short of a few screws and o-ring.
If you can't find the missing items in a hardware store, you will have to contact EK (http://www.ekwb.com/support/) since we don't have a replacement part section in the webshop.
I'm here!! :D
are the o-rings the same size to what is on the spacer's ive found 2 but they seem a bit to thick and a nightmare to put on, took me about half hour,just dont seem right to me, previous owner is sending the screws so just o-rings to get now.:) but i did look for screws and i couldnt find them anywhere, thought this should be on the webshop as there seems to be a few people that ask for this, going through the contact system takes time, maybe EK should do this as a buy, like a mini spare parts ie: a couple of screws ,orings, spacer,stop plugs. Just seems darf to me this isnt something you offer.
What do you mean by spacer?
