- 18 May 2010
- London
This bothers me and I have not managed to get a straight answer.
When you find out what your max FCLK is, do you change any voltages or do you just up the FCLK frequency and then apply the ram speed and see how it goes?
My 3700x for example if I set the FCLK to 1900MHz leaving ram at 2133MHz (basically untouched) the PC will happily operate like this.
I only see problems when I add the ram at 3800MHz to the equation.
I get audio corruption etc...
So do I have to apply any voltages to get the FCLK to work with my ram at 3800MHz or is it just a case that this wont work for me.
Last time I played with it I believe it took around 1.2v SOC to get rid of the audio corruption.
But 1.2v is too high for PCIe 4 devices from what I understand.
