Fear 2 options questions.
16 Nov 2008
West Midlands
I am not intirely sure what motion blur option does and if its better on or off, i also do not know much about the grain film option.
Motion blur is exactly what it says. When you're running or moving fast, the screen goes blurry. Film grain is like a noise over the picture a bit like interferrance or looks a bit like your tv is a bit out of tune. These are just visual effects to make the game feel more realistic
Motion blur makes the game look more fluid (think real life) by bluring the camera while it moves, it can also smooth out juttery frames while turning etc.
Film gran is a cheap gimmick they decided to put in to make it seem more like a gritty horror movie, it's aweful, leave it off.
I hate motion blur, but it is a personal thing.
It just blurs the background and some peripheral vision but you aint looking at that anyway are you.
Just finished FEAR 2 tonight actually. You need to play it on hard though. Sometimes you might need to switch to normal when you're a bit stuck and without and health, but hard setting is about right. Could do with a very hard setting really. Great game. Really enjoyed it.
