FEAR Saved file restore...where to put them
1 Dec 2004
S.Wales
I backed up a folder called
"Save" which held my saved points in fear.
iv re-installed fear and i put the folder back in the fear>userdirectory folder
but i cant load up the saved games?
inside the save folder that i backed up, i have 2 more folders.
profile00
and
profile01
inside these there are a number of files...
k what id do is this.
start a new game, play for 5 mins and then save it. (if its a checkpoint type game then well.. play longer :) )
once you have a 'valid' save you will have a reference template to sort out your proper saves.
GL, Lord Vader will fix your probs, dont worry (8<|
Doesnt work.
If i replace the whole folder, when i load up fear and select single player, the load option is greyed out as if there is no saved games.
Tried going into the game for 5 mins, saving and doing it that way but it dont work.
Weird......just had to do this myself and I did exactly what mittens said....and it worked fine. Sorry :(
But did you replace a certain file in the saved folder? or did you copy the whole folder over?
i did this with UT04 and altho that game let use the save fully i just took out the saves from the stored folder and dumped them into the new saves folder that came with the re-installed game
[Sniper][Wolf] said:
Was this profile folder in the root of the user directory folder, or was it:
user directory>save>profile001
Actually, looking at my FEAR folders now it's quite confusing. There's a profiles folder in the FEAR folder with just one thing in - then a profile000 folder inside saves which seems to contain the actual save games.
Looks like im going to have to start the game again :mad: What ever combo of file restoration i use, the load function in the game seems to grey itself out.
