Fedora 10 harddrive exact cloning?
6 Jan 2008
Hi there,
I'm thinking about changing an HDD in my Fedora system to something a little more robust but I was wondering how I would go about making an exact clone of the existing drive which I could simply swap over (without downtime - other than the hardware change).
What I'd like to know is how or what is the best method of doing this?
Thank you.
I'll second "dd", it worked perfectly for me when I was doing exactly what you're proposing, upgrading the OS drive without wanting to use a fresh install.
Hi sorry is there no GUI software that can be used. I really don't like the command line in linux because I don't actually understand what i'm doing and I cannot afford to lose the information.
Ok I've decided to use dd but its found some bad sectors on the existing driving. What would be the correct synx to use to pass through them?
It seems just about everything I'm trying is failing. I'm now attempting ddrescue but its cloning at a speed of less than 1kb (whereas before it was doing around 250mb a sec.
Is there anything else I can do it speed this up?
What command did you run? Its fairly simple to use DD, so im a little confused how its mucked up.
dd if=/dev/sda of=/dev/sdb
Where /dev/sda is the drive you are copying, and /dev/sdb is the drive you are copying to.
Hi that is right but because I have bad sectors I've run gddrescue -v /dev/sda /dev/sdb
But the problem is the cloning has really slowed down from 250mb to 1kb.
Does anyone know if I quit the process and restart it will it continue from where it was? What happens if I put it on another computer to recover will it continue?
No sorry. Dd failed because of bad sectors, so I loaded gddrescue to bypass the sectors.
The OS is a live cd, so nothing is happening on the orginial disk.
If the disk is bad, I reckon you'd be better off doing a clean install to be on the safe side - even if you're able to skip the bad sectors with a cloning operation, you may have some as-yet-undiscovered corrupted or missing data which could cause problems in the future.
Hmm. If the rescue has finished id run a SMART test on it, and show the stats here. If its truly goosed, as per the gent above id just get your data off and fresh install.
