Fedora 15 how do I find my wireless hardware
18 Oct 2002
Northants
Hi all,
I've been using Ubuntu for a while now but thought I would try Fedora 15, I really like Gnome 3 but I have an issue of my realtek wireless not being seen.
How do I find out exactly which wireless card it is in fedora? Bit dissapointed that it wasn't plug and play as per ubuntu/mint. If I can get it installed I would for sure stay with this as its rapid!
Cheers,
Sean
Well I found the terminal command to view wireless hardware but as I feared it just states 0 found. Kind of put a spoiler on me using this distro then :(
If its realtek it should "just work" - mine runs realtek fine (granted in Ubuntu). Can you not install Madwifi drivers for it? try using "module-assistant" to install it:
http://pkgs.org/package/module-assistant
Literally install (do it via YUM if its available), then run "module-assistant" from command line and away you go.
Yeh it is Realtek and it does indeed run fine and dandy in Ubuntu and Mint, fedora just doesnt see it at all which is a pain. I will have a look and see what I can do, thank you :)
If you do 'lsusb' and 'lspci' in a terminal then it should list the chipset of the wireless card. Google this plus fedora and it should throw up how to get it working.
