[...]I know with the corner based navigation that its a bit "out there" but thats kind of what i wanted, as almost everyone in the class has the same rough color scheme and layout so wanted mine to stand out a bit.[...]
It's admirable that you want to do something different; investigating alternatives to established conventions is a good idea and can result in better solutions.
But note that I said "investigating". What you're doing here is committing to an unconventional approach simply because it's an unconventional approach, rather than answering the question that the brief and medium poses:
is this the best solution for the problem of this site's navigation?
If you're serious about a career in design - any type, not just web - then you'll need to use the power of research and testing. I'm not saying that this project is the right place to start. But what I
am saying is that if you are serious, and you have a very good tutor, then you will gain respect/marks from showing your tutor that you investigated the corner-based navigation as part of your discovery process but found it wasn't the best solution for the brief.
Which it isn't, as myself and other posters are saying emphatically. Trust me, lots of designers have done the research.
Don't get me wrong - corner-based interface design has its place; there's a reason why Windows' 'Start' button is in the bottom-left corner, for instance. But that's because it's an interface on a finite, fixed-size monitor.
[...] I was maybe thinking of adding a small navbar with three buttons on being " back, home, forward" do you think that might help as if it is someone not used to different designs it might be more recognisable to them, i would still keep my corner navigation though, this small navbar would just complement it. [...]
What you're suggesting here is like designing a dog with three legs, then designing an artificial leg for it. Why not design a four-legged dog to start with?
[...] As regards to the little problems you mentioned, could you maybe elaborate as i want to get this site right.
What, and miss the snooker?!
One thing that'll help you, and gives further hints at why a corner-based nav may not be best:
View your site in Firefox. Now, go to View > Zoom and tick "zoom text only". Now zoom in, increasing the text size. Yes, some users will have text this big - and remember, your site has to meet the brief of being user-friendly for all types of people.
So, what happens? How can you solve this? What are the knock-on effects of you solving this?
