7 Dec 2008 at 22:49 #1 Berger Berger Soldato Joined 22 May 2003 Posts 10,856 Location Wigan Have a PS3 with Singstar on it. Noticing with the mics plugged in there seems to be a bit of static feedback through the TV. Is this fairly normal and is there any way of possibly reducing it?
8 Dec 2008 at 09:32 #2 ScarySquirrel ScarySquirrel Soldato Joined 13 Jan 2004 Posts 23,968 Location South East I find there is a lot of echo on mine, is that what you mean by feedback?
9 Dec 2008 at 01:26 #3 Yungstar 2006 Yungstar 2006 Associate Joined 8 Nov 2007 Posts 859 Location Tyneside Berger said: Have a PS3 with Singstar on it. Noticing with the mics plugged in there seems to be a bit of static feedback through the TV. Is this fairly normal and is there any way of possibly reducing it? Click to expand... sorry, can't help, but not noticed it on mine and it gets used fairly often.
9 Dec 2008 at 02:29 #4 meths meths Soldato Joined 12 Mar 2005 Posts 4,440 If it is feedback then move back a bit from your speakers or turn the mics down.
9 Dec 2008 at 10:54 #5 QPRHOOPS81 QPRHOOPS81 Associate Joined 3 Sep 2008 Posts 174 Lots of PS3's have this problem. Annoyingly the only fix i have found was to unplug the Ethernet cable. A bit annoying but worked for me.
