Feedback please for budget < £400
ajf
ajf
30 Oct 2006
Worcestershire, UK
I've been asked the usual 'what should i get' question again so would like some feedback on the suggestions I am going to give.
Main use is Office 2013 applications and web browsing.
Budget is MAX of £400 but less if possible.
No idea how the new range of AMD APUs compare to the Core i series CPUs.
I was thinking though that nothing is overly processor intensive so they would be better going for more RAM over more powerful CPU?
I know some can be upgraded later but with budget laptops it's a bit of a minefield.
Spec1 £330
Processor AMD E2-1800 (1.7 GHz, 1 MB cache)
Operating system Windows 8
Storage 750 GB HDD
PERFORMANCE RAM 6 GB
Graphics card AMD Radeon HD 7340
Spec2 £399
Processor AMD Quad-Core A4-5000M processor (1.5 GHz, 2 MB cache)
Storage 1 TB HDD, 5400 rpm
PERFORMANCE RAM 8 GB DDR3
Graphics card Radeon HD 8330
Graphics card memory 3.98 GB
Spec 3 £379
Processor Intel® Core™ i3-2348M (2.3 GHz, 3 MB Cache)
Storage 750 GB HDD, 5400 rpm
RAM size doesn't matter, 4GB is standard and is enough for your use. just like integrated graphics is. RAM is also probably the component that's the easiest to add/swap.
what I'd be more worried about is the actual manufacturer and model of the laptop, not just what's inside.
out of the 3 i'd choose Intel, but £400 can buy you better than that.
something like Lenovo B590 MBX2VUK or similar.
