Feedback required please.....
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys
What do you think of our newest case. Looking likely to have a great low price point as well.
Thank god!!!!
A new Antec case instead of rehashes of the 300/902/1200.
That new case does look nice.
USB3.0 with an internal connector I take it?
2 x 120mm in the roof for a 240mm rad?
Is there a cut out for a 8pin ATX in the top corner?
I like cases to be subtle (noise and looks) - so the bright colors are a turn-off. I use a p193 and I had a p180 before that.
I'd like a refresh of the p193 with a black interior, better cable management options, no 5" drive bays, SSD mounting on the floor or behind the motherboard, designed for having a dual all-in-one cpu cooler in the roof. Something like the Corsair Carbide 540 - but designed around being quiet.
Like said above the red and blue strips aren't great but not a major turn-off atall..
If this is priced around the same as the BitFenix Shadow, youre on to a winner here. :D
Exactly the same, great looking case, very subtle, then some garish cyan and pink/red tacky plastic on the roof, totally non-subtle?!
It is very distracting indeed :p had they both been a darker colour (like both being the same shade of blue as the LEDs inside), or removed entirely I'd like it a lot more.
