Feedback: Tubing
18 Oct 2002
Scun'orp
Some feedback for OCUK. I bought 5 metres of tubing the other day and rather than being one continuous length it was chopped up into 1m lengths. Tube I've bought from elsewhere has always come in one coil. I don't know about anyone else but personally I would prefer tubing to be supplied as one length so you can cut off the amount you want without the inconvinience of ending up with unusable off cuts out of a fixed 1m length. Mind you I don't need to buy anymore tube for the forseeable future so you can chop it into 1 inch lengths from now on if you like, but just letting you know incase anyone else has a view.
Same here. I then had to go and order more from somewhere else. They should make it clear that you only get 1m lengths. Most other places if you order 4m you get a 4m length.
Most of the pages show: Amount ordered = Hose length in meters
From that I woudl read if I ordered 10 I would receive 10m of tubing as one piece, unlikely but what if it was needed in section over a metre ?
Mabee you just got offcuts from the end of their big rolls?
Maybe, if they had 5 big rolls each with just over 1m left on them. Its probably down to it being easier for them to control stock as each length had a separate bar code label on it, coupled with the stock guy perhaps not knowing most water coolers would prefer a continuous length. Now they do though.
Last time i got some tubing from here, it was all one length (3m), guess it all depends on how they have it in stock really.
But that being said i generally get my watercooling stuff elsewhere as u get far bigger choice, sad really as id love to use Ocuk for all my stuff.
