- 19 Jan 2006
I need to install a fence post, however I know the position I'm looking to put it in has a concrete footing beneath for a perpendicular wall that juts out from the main house to form a flat roofed entrance area. The top surface of that footing I highly doubt to be at the 600mm depth I want to bury the fence post which leads me to figure out the best way to proceed. I'm looking to hang a 1m wide gate off this post.
I believe I've got two options;
Drill some 8mm holes in to that footing, drive in some rebar and post-crete the fence post in place on top of the original footing - using the original footing as support. I'd then need to cut the top of the fence post to suit the height of the rest of the fence. Con to this, likely won't have full 600mm of post buried in the ground.
Core drill a big old hole in the footing, kango it out, and sit the fence post at the correct depth, and backfill with postcrete - seems the smarter option, but could prove a PITA to achieve.
What are your thoughts?
