Just wondering, is there any way to set up a push/pull config on the Titan Fenrir CPU cooler? And if so can someone recommend me a second fan and a Y-splitter? Thanks a bunch
Intel builds the fenrir blows side to side, 2 decent elastic bands will hold the fan in place nicely there are no premade clips as it's not designed to hold 2 fans.
As for the fan I'd either try and match the Fenrirs stats as closely as possible or the stock fan and that way you'd have 2 identical fans
Is the fenrir really meant to blow side to side? I have mine with the logo horizontal, and the fan pulling upwards. Temps are still pretty good
I am tempted by a pair of Yate Loons in Push/Pull, but I have a feeling I'm gonna have to go for the Megahalems or the awesomely named "Super Mega" cpu cooler.
Heh, agreed. To be honest, it looks way worse than it is. nearly all those cables are pushed right back and run behind the hard drive cage out of the way for airflow.
