Ferrari Engine Placement?
Zip
Zip
26 Jun 2005
Australia
How do they do Ferrari Place there V engines?
Are they like this, like MR2s use
Or like this?
The black dots in the white squares are suposed to reprisent the pistons :p
Just curious how they have done it :)
Presumably longitudinal. Seeing as V8s and higher are pretty long when compared to a Japanese four pot.
Probably some variations in different cars, though.
Longitudinal (second picture).
(The plenum chambers go parallel to the car)
Both.
Nowadays they tend to mount them longitudinally (in the most recent ones) but they did a lot of tranverse fitted engines, like the 308 and the Dino. Think the Mondial was the last transverse one in the 80s? Can't remember :)
engine-compartment-center
And a longitudinal install in a 355 :)
>edit< forgot how good the 308 sounds, done the same job myself (balancing):
http://www.youtube.com/watch?v=38xaKmCSDx4
:cool:
BTW - a V8 will typically be the same length as a four pot....Think about it ;)
Sometimes they can lay lower as well, due to the angle of the banks, whereas a four cylinder will tend to be orientated close to vertical.
They are, overall, larger assemblies however and tend to be wider (obviously :))
come on zip, thats one of the easiest things to tell from any pic with the engine showing in the slightest on a ferrari. even a small google would have given you a very good answer!!
