Got a Panasonic plasma which came with some ferrite cores. Manual says to put them on the input cables but don't really see the need at the moment.
I do however get interference between my desk lamp and hifi amp/speakers. If I turn the light on/off while the amp is on then it makes an annoying buzz on the speakers. Would these ferrite cores help prevent that? If so where would be the best place to put them; the power strip cable, the desk lamp power cable, or the speaker cable?
Thanks
Thanks
