I recently cleaned out my loop and refilled it with some feser one, rather than the usual deionised water.
The fluid is clear but apparently will light up blue when under UV light.
I was thinking I may add a bit of colour to my case, I don't want lights poking out of everywhere so I thought maybe adding a dye to the fluid would be OK.
I thought red would be fine as I can already see the red LEDs from my sound card, mobo and RAM.
The questions are:
Can I add dye such as this:
http://www.overclockers.co.uk/showproduct.php?prodid=WC-035-PM&groupid=701&catid=193&subcat=1037
To my fluid even though feser say not to mix it with anything else?
Will adding more colour react with the UV stuff that is in there?
Do I need to spend £3 on a dy bomb like that or will 20p on food colouring do the job just fine?
Will the red look pink?
The questions are:
