Few Iphone questions help required please.
6 Nov 2004
Hi, is there anyway to transfer my mobile phone contacts from my Samsung U600 to my new Iphone?
All the contacts on my Iphone - how do I save these on my hard drive on my PC just incase my Iphone was to break so I don't lose my numbers?
Many thanks.
I dont think that you can transfer your contract on to your iPhone....
contacts, well I think that you can do it through iTunes, but I can't be 100% sure untill I get mine :)
Stelly
How do I sync my U600 to outlook and then to this Iphone, man this is proper complicating I can't find anything on the net with guides bah!
Ah thanks thats great, was less painfull than I thought, so If I were to add a contact to my Iphone will it auto add it onto my outlook contacts? so that it's always backed up?
there is an option in the new 2.0 software that lets you copy contacts saved from the sim. that's the easiest way i found!
Thought i'd answer my own questions - if you add a contact on the iphone when you next sync it'll add them into your outlook contacts, sweet!
