Hiya guys, getting a few eeors on my machine and wondered if anyone could point me in the right direction for solving them.
First one is this one below:
Event Type: Warning
Event Source: Userenv
.............. registry while an application or service was still using the registry during log off. The memory used by the user's registry has not been freed. The registry will be unloaded when it is no longer in use.
This is often caused by services running as a user account, try configuring the services to run in either the LocalService or NetworkService account.
For more information, see Help and Support Center at....
Second is this one:
Hanging application explorer.exe, version 6.0.2900.2180, hang module hungapp, version 0.0.0.0, hang address 0x00000000.
For more information, see Help and Support Center at ....
These are the only errors that i get in event viewer.
Nothing seems wrong most of the time, but every now and then it may freeze after the door on the case is shut? ANd tonight when i booted up it reckoned that my hard disk was not installed, i just rebooted and its been fine ever since. I have checked all the connection and that my mem was in properly etc.
The install is not that old, 2 months i guess, but have been using the same hardware since before crimbo and all been fine.
Was overclocked before i re-installed, but have not redone it since install.
ANy pointers would be great on this one.
Cheers in advance
Any ideas?
Event Type: Warning
Second is this one:
Cheers in advance
Any ideas?
