Maybe do some networking courses... but it depends on how hard you want to work.
Thanks for the fix
Did a science degree - never finished it for a number of reasons, one of them being the absolute snoozefest that lab prep work turned out to be =/ Might have just been unlucky there, but it turned me off for good.
1) Should I first sign up for a course in college then go uni afterwards or would a foundation degree followed by a sandwich degree be sufficient?
The sandwich thing I view as a must given a lot of threads going on here that people without industry experience are far less desirable than those with.
[J.D.C];17963564 said:Really worries me so many people suggest doing anything but IT and the like.
I'm quite excited about getting my placement sorted out, hopefully in some sort of developer/testing role and on the flip side, I keep hearing it's definitely the wrong way to go.![]()
Don't bother with a degree qualification, they're a big fat waste of money. Pick up some good programming books and READ them. Self teach. After a few months try and land your self a contracting role working from home. It'd prob only pay £100 a day, but once you fill your CV that'll quickly go up.
Any good books you'd suggest in particular?I love working in IT as a developer, but it has taken me a while to find the perfect job for me. I've worked for startups, multinationals and have now landed in a FTSE100 company with a fairly small IT dept and great benefits. I'd imagine the people who say "don't get into IT" are either
a) Support
b) Developers who haven't found the right job yet (there a lot of really crappy dev jobs out there)
anyone saying don't go into IT doesn't know what they are talking and/or is just stuck in a boring job which they are too lazy to do anything about. If its what you really want to do then do it.![]()
Any advice on how to know if it's a good job? I've worked with one sme, but it felt like a bunch cowboys when i arrived I.E No source control, no process, crappy code allowed etc. It really annoyed me.
Rather than live with it, that's the type of opportunity that lets you make a difference where you work. Source control is a no-brainer really... It shouldn't be difficult to sway people around to using it.
Personally, I love working in IT (i'm a .NET developer) but the downsides are that you can't be idle with your education. You always have to keep on learning to keep up with technology otherwise you can quickly left behind, even in the same job!
If you are going to do IT then definately shoot for a development type role. Avoid IT support if you possibly can. Sure if you are lucky enough to end up with a high end role or work for a decent company its good. However there is a lot of grief and drudgery involved in most 1st / 2nd line IT support jobs.
30 posts on, I'm still none the wiser =/ Aside from people who are advising against an IT career altogether the options presented are:
- self taught with a freelancer job experience that may or may not lift off the ground
- uni that, while may provide qualification, may turn out not being useful in the long term
- specialised course
So of them three - which one would you agree, to be the best choice?
Thanks for the tips mateAny good books you'd suggest in particular?
where are these contract roles working from home after 'a few months'?
Sounds like crazy talk.
As an ex-IT guy, suggest you don't waste your time, you are lucky to have a job as there are virtually none (pretty much means none) in this field unless you are specialist.
Utter nonsense. Do you live in a hole?
