Few questions about K800i
25 Nov 2006
Birmingham
Hi,
I will be getting a K800i next week, as my cousin can get a discount. So I should be getting a Pay as you go K800i on O2 for £135 which is brand new.. There is a few things I would like to find out, do the O2 K800i's come unlocked?. As I was thinking about getting a Vodaphone PAYG sim for the free weekend calls and also the free text with out having to top up. If the phone is not unlocked what are O2 PAYG sims like. Do you get free minutes ect?
And the last thing is, If the phone is 02 branded will I be able to update the firmwire?
Thanks.
O2 phones are usually unbranded and unlocked to all networks.
O2 sim card will be 200 free text or x amount of minutes free per month when you top up by £10.
And yes you can update the firmware.
I went down to the shopping center today, and I bought the K800i for £150 on vodaphone and it came with a free £25 vodaphone VBH-300 bluetooth headset. I have to say I am very impressed with the phone after 2 hours of use. I have yet to buy a memory card which I most likely will buy a 2GB or 4GB one tomorrow. The sound quality on the earphones is so much better than on my Ipod 5th gen 30gb. Does anyone know any good sites for themes, games, apps for the K800i.
Thanks.
300 free texts for £10
500 free texts for £15
1000 free texts for £30
Jon
