Few questions about Samsung 913N
20 Jun 2005
London..
Just bought a Samsung SM-913N 19inch LCD(bgrade) from here and i got a few questions.
1) Does it come with a wall mount
2) Can i plug my PS2 into it
Thanks
no wall mount with it, but it is VESA certified so you can buy one seperately. You would need a TV card in the PC to plug PS2 into it, since the monitor just has a single VGA input, no component or anything
Hi Badass. Cheers for replying ;)
So i should be looking for a VESA wallmount?
About the PS2, is there any sort of 3rd party add on like some sort of box i can use to plug my ps2 into and then into the monitor?
you'd need a VESA compatible wall mount yes. Check the panel spec to ensure you know which type but iirc it's a 10/100mm standard. Regarding the PS2, i'm not sure if you could achieve this through an xxxx (ahhh, i can;t remember the name of it - some kind of box, it will come to me and i'll come and edit this! :p)
wall mount kits? well it depends what type you get. We can't talk about them here specifically as almost certainly anywhere which sold them would be classed as a competitor. They vary in design, built, looks, price, make.....lots to choose from :)
Wahay thank you i shall look around. Do you think its worth playing PS2 on a 19" LCD monitor over a 14"tv?
Err mate are you sure they are KVM switchers because what im reading is that they allow you to control 2 pc's from one terminal, nothing about consoles..
that was what i was thinking of, but wasn't sure they would be suitable. I am not sure if there is an equivalent box to allow what you are thinking of. Hopefully someone else might be able to help though :)
you will need a vga>console converter. theres plenty around if you search, mainly for the xbox though but it will sork fine on the ps2
lowrider007 said:
So did I, :( , what time did you order yours as I think they've only usually got one stock item of "b grade" items.
I ordered mine at around 4:30PM yesterday(21/04/06), you?
