- 2 Jul 2008
http://www.overclockers.co.uk/showproduct.php?prodid=MB-051-AK
Asrock Z68 Extreme4 Intel Z68
I'm thinking of getting a smoking rig lined and up this board seems to be getting the thumbs up from many on this forum. As always I trust the "mob wisdom" on this site so have it pegged as "the" main board for my SB rig.
And BANG for BUCK CPU right now seems to be Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155, especially with its easy OC'ing cababilities.
www.overclockers.co.uk/showproduct.php?prodid=CP-360-IN
stop me if I talk no good btw :-/
In the past I think I have over spent and this time round I really want to get it right in the sense that I am not way over spending to next to no real performance gains etc from spending less if you get me.
I'm also going for AS QUIET (pref Silent) as possible. So am carrying over my Passive cooled ATI 5450. And from what I can gather this almost silent power supply.
XFX 750W Black Edition Modular Power Supply
www.overclockers.co.uk/showproduct.php?prodid=CA-001-XF
?? (seems to run next to silent according to reviewers)
I need some advice on memory now as I'm finding it a bit of a mind field.
the top speeds supported from the memory compatibility list is from mid way 1600 mhz all the way to 2400 mhz (OC).
So do I fork out for some top level 2400 stuff and get the top speeds, or do i peg it some where in between, say, 2100 mhz, save some cash and not really notice any difference etc.
I could really do with 8 GB for VM's and various things.
I "pencilled" in this.....
http://www.overclockers.co.uk/showproduct.php?prodid=MY-056-GS
x2 to make 8 GB (although all mem slots filled can affect power draw I hear, so maybe the equivalent 2 x 4gbs ???)
Any tips or build lists of known working memory with this board and CPU would be great.
Also I'm hoping to get somewhere between 4.5ghz 4.8ghz OC with this board and chip and am hoping to get confirmation that with this BIOS you can do it VERY easily, perhaps AUTO even.
Then of course I need as quiet (pref SILENT) a fan/heatsink as possible.
I have "pencilled" this one as a potential suitor (but change fan to sharkoon silent eagle)
http://www.overclockers.co.uk/showproduct.php?prodid=HS-001-CS&tool=3
What do you reckon?
oh I need the smartest, not too big case, with good cable management. I love the lian li's but can never decide on the most suitable one. I had a HAF 2 and that was just too big and noisey although very good case overall.
I was close to going down the SSF route latley but decided against it.
As far being almost ready with a final set list I think I'm there, just hope you can help fill in any blanks for the grey areas. Thanks guys!
What do you reckon?
