First would someone be able to measure the distance between the motherboard and the side of the case to where the 4 fan panel is. I'm curious if I would have enough space for my CPU cooler (Ultra 120A) and Side fans.
Are the fan holders individually removable from the fan side panel?
Are there holes on the bottom for additional fans?
Can any fans be added on the roof on the case? (Where the Raptor window is)
How many harddrive cages are supplied?
Is it the same tray that is used for both ATX and BTX layouts?
