Hi,
Been browsing OC for about 2 months now and just joined to ask a few questions. First Post o_O
I am planning on getting a new comp at some point after new years. Now I usually just buy a whole new set, but I am tempted to may change components and upgrade
Just for reference this is my current specc. (and i mostly use comp for gaming/movies/music etc)
Case: Antec P180 Silver
Power Supply: Antec True Power Trio 650W
Processor: Core 2 Quad Q6600 8MB cache
CPU Cooler: Thermaltake Golden Orb Cooler
Graphics Card 1: BFG GeForce 8800 GT OC 512MB PCI Express
Graphics Card 2: BFG GeForce 8800 GT OC 512MB PCI Express
Memory: 8GB Corsair DDR2 XMS2-6400C5 Twin2X
Motherboard: Asus P5N32-E SLI Plus Socket 775
Hard Disk Drive One: 320GB Caviar SE16 SATA 300
Hard Disk Drive Two: 320GB Caviar SE16 SATA 300
Optical Drive One: BTC DVD-Rom x16
Optical Drive Two: NEC 4570A DVD-RW
Now to my questions, apologies in advance for my ignorance etc.
I currently use a 22” screen and am going to upgrade to something in the range of 27”. My first question to play at higher resolutions, are you better of with a single high end GPU vs 2 mid range (GTX460) in SLI?
Secondly I been eyeing the overclocked bundles on OCuk, it has been stated that if you wanted more “ram” then they may not be able to reach the same overclocking as with the amount ram listed. I assumed overclocking a processor depends on the mobo, the processor and the cooler etc.
Thanks,
Thanks,
