- 17 Jun 2005
- Near Brighton
Going to rebuild my watercooling this weekend probably, wanted to ask a few things.
Im going to buy all new tubing, but its been so long since i built it that i cant remember the size i need. The inside diameter of my current tubing is 1/2 inch, so i assume thats the tubing i need?
second question is order of the loop.
At the moment its setup as follows:
Pump - Rad - Cpu - Gpu - Chipset - Res however i think it may be reversed by accident
Whats the best loop? I assume Chipset - Cpu - Gpu - Res - Pump - Rad would be.
Thanks
Thanks
