FFDSHOW 64Bit - Latest Build Thread
Does anybody here have it and VLC installed on the same system? VLC's great for a single standalone program that seems to play anything that can be thrown at it. However the last few builds have been terrible and apparently the quality of it is not very good compared to other programs out there.
Nope i just have ffdshow installed , coreAVC & media player classic home cinema...
FFdshow is set to
( use only in dllhost.exe;mplayerc64.exe; ) ,
Codecs ( rawvideo all supported) , (H264/AVC Disabled)
Subtitles / Sharpen (xsharpen) 25/150.
Quality is great , everything works and games use the correct windows codecs and isn't messed up by other codecs (oblivion e.t.c).
No messing about here , just install 64bit ffdshow , load ffdshow only with ".exe and thats it!. I use media player classic 64bit myself :)
Anyway
ffdshow_rev2547_20081228_clsid_x64.exe
never evn knew there was an x64 version of mpc. hehe
Nice thread. Been playing some HD content on Vista x64 with VLC and having some problems. Will try ffdshow x64 and MPC x64 and see if the errors go away. :)
I tried this about 6 months ago and it was awful for x264 films, the 32bit version was much better. Has it got to the same level as the 32bit FFDshow?
