I see you are using MPC, do you have ffdshow video decoder loaded as an external filter? Otherwise MPC will use it's internal filter and not those settings.
Edit: But now I see it has the OSD displayed, so it must be using those settings... try specifying the size instead of multiplying.
The internal filters for video are excellent in MPC and scaling is perfectly fine - like you saw, there's not much difference to be observed upscaling SD content so standard scaling (native) is the best way to go about it.
I have it configured to decode audio through the official AC3 filter which is higher quality than MPC's built in audio mixer but all video is through MPC/DXVA.
I only installed ffdshow because the 3gp codec was needed and nothing more really!
