The Saab 9-3 saloon also uses the 150bhp 1.9 version of the JTD engine as do some Vauxhalls. It's not an engine that has a reputation for going 'pop'.
And Alfaromeo are getting the 190bhp version of that engine, saab will have it in 180bhp form too.
The JTD-m/multijet is the most advanced diesel in mass production, bar none! It is as reliable as you need, comes in several different states of tune depending on what you buy it in.
As mentioned, FIAT have been ahead of the game with diesel for a long time, the 1st direct injection diesel on the roads was the old Croma, and they were 1st to the market with these new high pressure diesels.
If you are interested in the technical bits, the multijet makes 5 injections per cycle.
1. Pre-injection (heat the air to take the knock off).
2. Another pre-injection.
3. Main charge.
--- at this point the acceleration of the piston down the bore is measured ---
4. Correction injection, smoothness
5. Post injection when cold to heat up the CAT.
Edit: Beware of BMW's figures, they have a business practice of publishing figures obtained from their lighter more aerodynamic cars, so the mpg figures are to be taken with a shovel of salt.
