- 5 Mar 2006
- everywhere
Hi,
Thanks for suggestion.
Not got access to fault finding kit any more as the guy has gone.
Any idea of coilpack or headgasket repair costs?
Sorry, just trying to figure out if we need local fiat franchise or any other garage would do? - why does this stuff always happen at worst possible time?!
Cheers
I wouldn't bother sending a car that old to a main agent.
If it's a headgasket problem it is likely to do more damage if you carry on using the car. Have a look at the oil, if it looks like rancid mayonnaise then it's defiantly the head gasket (although don't rule it out if there's a complete lack of mayo).
Hi,
Cheers
Disconnect the other 3 coil packs in sequence,it should get worse when started each time - I.e check coil 1 makes things worse, reconnect and move onto 2, you should notice little to no difference doing this with coil 3 - if so just replace it
Do we get coil pack replaced then see if that fixes it then move on to consider HGF? Or is there some diagnostics can be done before spending the money on coil pack?
Sell it and buy something reliable.
VAG cars are unreliable, nothing new there. Just because they're well built doesn't make them reliable.A coil pack failure on an 8 year old car makes it unreliable? What does that make all the VAG cars that had coil pack failures within the first year?
