Okay i need help with the following items please, there are 12 items in questions, constructive critisism only please!
1) Nearside front position lamp(s) not in good working order (not working)[1.1.4a]
Headlight bulb change, quite obv..
2) Offside headlamp aim too low [1.6]
Easilly sorted?
3) Registration plate lamp not working [1.1.5c]
What sort of bulb is this?
4) Offside rear fog lamp not in good working order (not working) [1.1.6b]
Again, what sort of bulb is this? Might sound dumb but i didnt know you had a rear fog lamp
5) Offside rear position lamp(s) adversely affected by the operation of another lamp [1.1.4d]
Indicators? Bad earth? Way of sorting?
6) Offside stop lamp adversely affected by the operation of another lamp [1.3.2g]
7) Offside rear direction indicator adversely affected by the operation of another lamp [1.5.ale]
Both bad earths??
8) Further to this thread Offside (front to rear) Brake pipe excessively corroded [3.6.b.2c]
Now, im not covered any more, it was already changed back in 2003.. So i need to do it myself but apparantly its like half inch wide pipe? Can i not just weld a copper pipe in there??
9) Offside front brake binding
Can i do this myself?
10) Nearside Front suspension arm rubber bush deteriorated resulting in excessive movement.
Whats this?
11) Nearside front front brake juddering severly [3.7.a.2b] **DANGEROUS**
What could be causing that?
12) Front Brakes inbalanced [3.7.a.2e] **DANGEROUS**
Not a clue about this..
Help me please
Easilly sorted?
Both bad earths??
Whats this?
Help me please
