25 Nov 2024 at 20:37 #1 ver01@ ver01@ Associate Joined 7 Aug 2017 Posts 1,907 Location Oxford Is it possible to connect the MESH directly to the open reach box? The MESH has LAN and WWAN ports
26 Nov 2024 at 18:47 #2 Broken Hope Broken Hope Soldato Joined 16 Jan 2003 Posts 10,913 Location Nottingham Sure you just need to know the username and password if it uses PPPoE.
26 Nov 2024 at 18:52 #3 ver01@ ver01@ Associate OP Joined 7 Aug 2017 Posts 1,907 Location Oxford And the telephone will go straight from the Open Reach box to the telephone (instead of the Sky Modem/router)? Last edited: 26 Nov 2024
26 Nov 2024 at 19:55 #4 Caged Caged Man of Honour Joined 18 Oct 2002 Posts 26,830 No It would really help if you listed the model numbers of what you’re using and clarify if this is FTTP or not. Last edited: 26 Nov 2024
27 Nov 2024 at 09:07 #5 ver01@ ver01@ Associate OP Joined 7 Aug 2017 Posts 1,907 Location Oxford It's Sky Fibre and the Mesh is Tenda Nova AC1200.
27 Nov 2024 at 10:58 #6 the-evaluator the-evaluator Soldato Joined 24 Sep 2015 Posts 4,119 Fibre to the Premises (FTTP) or Fibre to the Cabinet (FTTC)? Do you have a fibre cable into your house or the connection over a copper telephone line?
27 Nov 2024 at 14:37 #7 ver01@ ver01@ Associate OP Joined 7 Aug 2017 Posts 1,907 Location Oxford It's FTTP
27 Nov 2024 at 15:24 #8 Caged Caged Man of Honour Joined 18 Oct 2002 Posts 26,830 If your telephone plugs into the Sky router then the only way you can keep your phone line is to keep the Sky router
27 Nov 2024 at 20:18 #9 ver01@ ver01@ Associate OP Joined 7 Aug 2017 Posts 1,907 Location Oxford You are right. Mixed up the cables
