Fibre optic sound cable
28 Nov 2004
Hi
I bought an expensive cable for my xbox360, video is fine, but the audio cable is fibre optic, and my hd telly (panny pv500) dosnt seem to have a fibre optic input, anyway around this with adaptors etc?
Thank
Shaun
Which cable exactly did you buy?
Most should come with a red/white plug which your TV should have.
The optical cable is for 5.1 audio mainly and needs to be used with a Dolby Digital receiver.
If the cable doesn't have stereo RCA plugs then I don't think you'll be able to get sound through your TV.
If your sound system has a optical in you can use that, or if it has a coax input then you can get an optical->coax adaptor for £20 or so IIRC.
I know this isnt the official lead i got with the xbox, what i need to know is, is there any way to get it working with my panny pv500 ? :)
You could buy a Dolby Digital decoder unit and take the outputs of that in to the TV, but it'd be cheaper to take that cable back and buy the official one.
As what Phil99 and Rich_L have said, to use the optical cable, you need a device that is capable of decoding Dolby Digital, which is usually in the shape of an amplifier or mid-high range all-in-one DVD player. There is no 'cheap' option to convert that 5.1 signal to anything other than another 5.1 digital signal (i.e. coax from optical).
Otherwise, you have to use an Xbox 360 cable that has normal 2 channel sound (Red/White). It's kind of silly that that cable doesn't come with normal 2 channel sound.
