Fibre Router Required... Help
4 Mar 2004
Peterborough
Hello,
I am looking for a new router for my 80mb plusnet. It must have very good wifi (plusnet hubs not great), able to VPN in and price around £130 ish.
What are the netgear nighthawks like? or is ASUS the way forward?
What flavour of VPN do you want? I assume you're after a router that'll act as an endpoint?
Keeping the Openreach modem potentially gives you a wider choice of routers.
There are an increasing number of routers with the VDSL modem built-in if a single box solution is important top you.
