Fibre testing
19 Jan 2010
Chipping Norton
Hi Guys
i'm currently testing a lot of old 200um fibres.
but something doesn't add up.
We have 2 big bulkhead cubicles from which we spread out to certain ares.
for these i usually use a launch fibre to get the measurement.
so the launch fibre currently reads in at -10.2dBm
the acutal fibre without the bulkhead measures at -8,5dBm
i later on changed the bulkhead because the reading was too low.
now the measurement for the full length (launch fibre - bulkhead - main fibre) is -14,8dBm.
someone told me i could just subtract the launch fibre measurment from the full measurment but this doesn't add up at all. :confused:
could someone be so nice and explain this to me?
thanks
sorry forgot that i posted here.
these fibres are not fusion spliced they are just old SMA ends connection through a straightthrough bulkhead, guess that's how they used to do it 20 years ago ;)
equipment is just a normal light source and meter i would have thought?
but i found an answer anyway.
it seems that the light source is already "running" at around -7dB as the light source does not directly inject light into the fibre. so i found that measuring the loss of the launch fibre in dBm and the measuring the actual fibre including launch fibre in dBm.
these 2 figure can be subtracted to get the actual fibre loss in dB. :)
at least that's what it said on a website :p
