- 22 Jul 2009
- United Kingdom
Hi All,
My bonnet is badly damaged, beyond repair really so I need a new one!
I have looked at GRP bonnets and have found one that looks really good quality with all the standard fittings and strengthening etc.
Im just a little unsure of a couple things,
- Do you think it will rattle/flap around even though it has strengthening?
- Do you think it will be get a good finish paint work wise? (in black)
u can get a good finish in any colour so long as you know how to paint finish depends on quantity of paint, ammount of pressure and the ammout of product you put on, not just the panel. you could always flat and polish it
