Fiddling Ports
22 Jun 2005
Nottinghamshire
Basically I have a piece of software that will ONLY print to the port LPT1, there is no option about this.
I have a printer that will only connect via usb, is there a way of printing to the printer from the software, as I can't ask it to print to the USB port?
Thanks!
Is your pc networked? The reason I ask is that if it isnt, then you need to install the microsoft loopback network adapter for sharing to function properly.
