Hi there,
My GF's Fiesta 1.25 has a few issues I am looking to sort for her.
It's a 2000 W reg, so that makes it a Mk5.
One of the rear brakes, a drum and shoe setup binds when not driven for 6 or more hours or so, it makes a clunk as soon as you pull away. I am thinking there could be moisture in the drum which is rusting the shoe and drum together? I have some brake parts cleaner but I failed at my last attempt to get the drum off, it just wouldn't budge!
My mechanic friend recommended to loosen the handbrake off. Where is the handbrake adjustment on the Fiesta? The handbrake is also quite high so I need to adjust it anyway.
The second issue is also brakes related and could be linked to the poor drum performance. The brake pedal feels very odd and doesn't give much confidence with stopping the car. The pedal will travel a fair bit with no response from the brakes. The pedal doesn't feel well connected to the brakes, it feels as if the brakes couldn't stop the car that well.
I have replaced the brake fluid as the existing stuff was disgusting. I bled the system out but perhaps not well enough and there is still air in the system? The problem existed before replacing the fluid. Perhaps the pads are cack but would this make much difference? So, suggestions on this problem please.
Third issue is water getting into the boot. I have taken off the light clusters and put a bead of silicone around them. I think the water could be getting in from around the boot lid seal. Is this a common problem or such? What's a good cure to try?
All input very much appreciated!
Thanks!
Thanks!
