Fiesta bulb recommendation
20 Oct 2002
North West
Can anyone recommend any replacement bulbs for my 2015 fiesta? It’s the main headlights.
Also, what’s sites do you use? I’ve found power bulbs uk but have no idea really
You want to check if they're halogen or xenon. Easy way to tell is if you have headlight washers. No = halogen, yes = xenon.
As above, Osram Nightbreakers are considered the best well priced option for halogen. There's a couple versions, go with your preference on output.
I haven't used Osram before so can't comment on them, but I'm using Philips Racing Vision GT200 on my 16 plate Fiesta ST and they've been good. Got them on Amazon when on offer for £22.50
Fiesta titanium that I’ve had since new - no wipers on light if that’s what you meant?
I have headlight washers. Headlights are definitely halogen and I've seen many other makes/models supply headlight washers on halogen so that's not always true.
Tbh I don't think the mk7 came with a xenon option. They had halogen projectors, using H7 bulbs.
I have these in our S-Max and they were in my ST170 before it went to scrap
Philips WhiteVision ultra H7 car headlight bulb, 4.200K​
Yeah one of the vehicles I currently own and the one before that had headlight washers with halogens.
Personally prefer Philips Xtreme or Racing vision as the colour biasing makes things stand out more in the dark than other bulbs.
Bought a set of racing vision for 24.xx from amazon
Now to look up how to change the bulb :p
