For the past 8 months or so my Fiesta 1.25 has developed a problem where it will judder slighty when you set off, sometimes it is worse but other times it is not so bad. It also does it when changing from 1st / 2nd / 3rd etc but once I change to 4th it doesn't do it. The judder does not happen during normal acceleration but only when setting off or as mentioned changing from 1st / 2nd / 3rd. I have already changed the plugs, leads & coil pack but the problem still persists. I am pin-pointing the problem down to either the clutch (car has only done 64K and the clutch is not slipping though) or another part called the Fuel Pressure Regulator maybe? Could someone possibly help me out with this problem?
Thanks all - Liam
Thanks all - Liam
Was hoping it is not the clutch but it would make sense as my gf's Fiesta had a new clutch just before she got the car in August & her car changes gear brilliantly and feels really smooth and no juddering at all. My car seems to really judder more when setting off on a hill or changing gears when driving up a hill. Can a car's clutch still be on its way out even if its not slipping then? Are there any other tests I can do to see if it could be the clutch? (I have forgotten the 3rd gear on the hill start test, could someone explain it to me?)
Would help if you had an engine lift - most garages can do it same day if they can get the clutch that day and they aren't rammed full (or so they claim).
