- 28 Jan 2005
- Southport
Hi all,
My mum has got a X reg fiesta and the battery had gone flat so we are charging it up and its starting fine now. With the charger on the battery there is about 14v going into the battery.
On my focus with the car idle there is 14v through the battery which is normal. Now on the fiesta is under 13v... does this indicate the alternator is going bad or is it that the battery has been flat recently?
Thanks
Thanks
