Fifa 08 Goals
25 Sep 2003
Hey guys ive just made a video of some of my goals ive scored while palyig fifa 08 online on the pc, if anyone else has it on the pc give me a shout and we can have a few matches, anyway heres is my video :)
some quality goals there, but ive only got pes 2008, thinking of getting fifa to see the difference. if your good at pes would you be able to play fifa good as well or is it completely different?
Well i used to play pes until 2008 was a bit rubbish online, it didn't take me long to adjust to the fifa style of play, only thing i had to do was swap the shoot and cross buttons around so it was like pes controls apart from that they r the same. If u do get it give me a shout and i will help u out.
Seems the cpu setting is on amateur, you are just walking through players, put it on pro or world class then post some goals :P
FIFA 09 is out early October, id wait. Should have next gen engine aswell.
XBOX 360 n PS3 versions use next gen engine, PC uses crappy PS2 "old" gen version with no decent Widescreen res` supported. Damn u EA damn u !
