- 7 Feb 2004
I have been having some trouble with my gamepad on fifa 09 demo and have found a solution.
This issue was not letting me map the buttons and was just giving an empty for the button. Although i have not tested I think this should work on most gamepads. It did on my logic3 rumble pad.
The file that commands these is located in:
Program files\fifa 09\data\input\devdat.dat
Open with a notepad and add the following line at the end before ENDOFFILE
If you go to your control panel and see what your controller is called, mine was something like USB Controllers or something like that. Rename the "Name of controller in control panel" to your gamepad and all should be good!
[Name of controller in control panel|Name of controller in control panel]
DEADZONES=0.3,0.3,0.3,0.3
2|24|3,2|25|4,5|26|5,5|27|6,1|22|5,1|23|6,0|20|3,0|21|4,0|18|21,0|19|22,0|16|19,0|17|20,0|1|2,1|3|2,2|0|2,3|2|2,4|10|2,5|13|2,6|11|2,7|14|2,10|9|2,11|8|2,8|12|2,9|15|2
2|24|3,2|25|4,5|26|5,5|27|6,1|22|5,1|23|6,0|20|3,0|21|4,0|18|21,0|19|22,0|16|19,0|17|20,1|1|2,3|3|2,0|0|2,2|2|2,4|10|2,5|13|2,6|11|2,7|14|2,10|9|2,11|8|2,8|12|2,9|15|2,1|4|2,3|5|2,0|6|2,4|7|2
Hope that helps a few of you guys like it does me!
